Commit e2e95e5e authored by Marek Vasut's avatar Marek Vasut Committed by Tom Rini
spi: Update speed/mode on change
The spi_get_bus_and_cs() may be called on the same bus and chipselect
with different frequency or mode. This is valid usecase, but the code
fails to notify the controller of such a configuration change. Call
spi_set_speed_mode() in case bus frequency or bus mode changed to let
the controller update the configuration.
The problem can easily be triggered using the sspi command:
=> sspi 0:0@1000
=> sspi 0:0@2000
Without this patch, both transfers happen at 1000 Hz. With this patch,
the later transfer happens correctly at 2000 Hz.
Signed-off-by: default avatarMarek Vasut <marex@denx.de>
Cc: Jagan Teki <jagan@amarulasolutions.com>
Cc: Patrick Delaunay <patrick.delaunay@foss.st.com>
parent 605cbcb0
