Commit 3dcb861d authored by Eric Auger's avatar Eric Auger Committed by Rafael J. Wysocki
ACPI: VIOT: Fix ACS setup
Currently acpi_viot_init() gets called after the pci
device has been scanned and pci_enable_acs() has been called.
So pci_request_acs() fails to be taken into account leading
to wrong single iommu group topologies when dealing with
multi-function root ports for instance.
We cannot simply move the acpi_viot_init() earlier, similarly
as the IORT init because the VIOT parsing relies on the pci
scan. However we can detect VIOT is present earlier and in
such a case, request ACS. Introduce a new acpi_viot_early_init()
routine that allows to call pci_request_acs() before the scan.
While at it, guard the call to pci_request_acs() with #ifdef
CONFIG_PCI.
Fixes: 3cf48554 ("ACPI: Add driver for the VIOT table")
Signed-off-by: default avatarEric Auger <eric.auger@redhat.com>
Reported-by: default avatarJin Liu <jinl@redhat.com>
Reviewed-by: default avatarJean-Philippe Brucker <jean-philippe@linaro.org>
Tested-by: default avatarJean-Philippe Brucker <jean-philippe@linaro.org>
Signed-off-by: default avatarRafael J. Wysocki <rafael.j.wysocki@intel.com>
parent 88084a3d
