x86 UEFI: Make run_tests.sh (mostly) work under UEFI
Make several fixes so that run_tests.sh can run the test cases when the repo is configured to run under UEFI. Specifically: 1. The scripts are enlighted to run the .efi test cases rather than the .flat test cases. 2. The scripts are enlighted to run an empty file, _NO_FILE_4Uhere_, which is used to sanity check QEMU and QEMU flags. 3. The scripts are updated to always run with `-smp 1`, since SMP is not yet supported under UEFI. Notably, QEMU's `-append` flag still does not work. This will need to be fixed in future commits. For now, test cases that use `-append` are marked `SKIP`. Signed-off-by:Marc Orr <marcorr@google.com> Message-Id: <20211116204053.220523-9-zxwang42@gmail.com> Signed-off-by:
Paolo Bonzini <pbonzini@redhat.com>
