plat/common: Remove duplication of plat_crash_console functions/stubs
Commit e74afb65 (Deprecate weak crash console functions) deprecated the default inclusion of weak definitions for plat_crash_console functions in plat/common/aarch64/platform_helpers.S. The code was later copied out to plat/common/aarch64/crash_console_helpers.S so platforms can link it explicitly if they want to. However, since deprecation does not mean removal, the same code is also still duplicated in platform_helpers.S. The duplicated code contains both empty stubs for the !MULTI_CONSOLE_API case, and a real implementation that used to work but was broken by commit d35cc347 (Console: Use callee-saved registers) for MULTI_CONSOLE_API. It's not great to have both of these duplicated in two files, so this patch splits them up: in platform_helpers.S we'll only keep the empty stubs (guarded by !ERROR_DEPRECATED), which should not regress functionality since the MULTI_CONSOLE_API implementation was already broken anyway. In crash_console_helpers.S, we'll only keep the MULTI_CONSOLE_API version, which is enough both as an implementation in itself and as a sample for how to reimplement these functions in a platform-specific file. Change-Id: I83d95a90ab6aac597dc2ea2f2797ac2c8ed075d4 Signed-off-by:Julius Werner <jwerner@chromium.org>
