You need to sign in or sign up before continuing.
Merge tag 'drm-intel-next-2021-03-16' of git://anongit.freedesktop.org/drm/drm-intel into drm-next
Highlights: - Alderlake S enabling, via topic branch (Aditya, Anusha, Caz, José, Lucas, Matt, Tejas) - Refactor display code to shrink intel_display.c etc. (Dave) - Support more gen 9 and Tigerlake PCH combinations (Lyude, Tejas) - Add eDP MSO support (Jani) Display: - Refactor to support multiple PSR instances (Gwan-gyeong) - Link training debug logging updates (Sean) - Updates to eDP fixed mode handling (Jani) - Disable PSR2 on JSL/EHL (Edmund) - Support DDR5 and LPDDR5 for bandwidth computation (Clint, José) - Update VBT DP max link rate table (Shawn) - Disable the QSES check for HDCP2.2 over MST (Juston) - PSR updates, refactoring, selective fetch (José, Gwan-gyeong) - Display init sequence refactoring (Lucas) - Limit LSPCON to gen 9 and 10 platforms (Ankit) - Fix DDI lane polarity per VBT info (Uma) - Fix HDMI vswing programming location in mode set (Ville) - Various display improvements and refactorings and cleanups (Ville) - Clean up DDI clock routing and readout (Ville) - Workaround async flip + VT-d corruption on HSW/BDW (Ville) - SAGV watermark fixes and cleanups (Ville) - Silence pipe tracepoint WARNs (Ville) Other: - Remove require_force_probe protection from RKL, may need to be revisited (Tejas) - Detect loss of MMIO access (Matt) - GVT display improvements - drm/i915: Disable runtime power management during shutdown (Imre) - Perf/OA updates (Umesh) - Remove references to struct drm_device.pdev, via topic branch (Thomas) - Backmerge (Jani) Signed-off-by:Dave Airlie <airlied@redhat.com> From: Jani Nikula <jani.nikula@intel.com> Link: https://patchwork.freedesktop.org/patch/msgid/87v99rnk1g.fsf@intel.com
